Farmall A gonernor
tractorhead
05-24-2005 05:36:26
The bumper spring screw on the bottom of my governor shows no tension when turning the screw I suspect the spring is broken or missing. does the governor have to be disassembled to get at it. is it a difficult job for someone who has never worked on a governor?....thanks jimmy
scotty
05-24-2005 05:59:10
 Re: Farmall A gonernor in reply to tractorhead, 05-24-2005 05:36:26
Tractorhead, Just remove the acorn cap on the bottom, loosen the jam nut and back out the screw with a screw driver. The spring is inset in the end of the screw in a counterbore. Replace the spring and assemble. Hope this helps.
scotty
tractorhead
05-25-2005 05:55:29
 Re: Farmall A gonernor in reply to scotty, 05-24-2005 05:59:10
scotty; It worked as you said, but the tractor didn't work as I thought it should so I removed the screw again, no spring the governor ate it!!the scrrew had a deep recess so I wonder how that spring got out! Hmmmm I'm not sure what to do next.
