IH240 3-point
North1
05-29-2005 17:33:40
Brother-in-law just bought a 1959 IH 240 tractor and is having some problems. As he explained it, when he lowers the 3-point hitch with tiller it will not go into float. It will actually want to try to raise the back of the tractor up. He was told by a local mechanic there is probably parts missing but the didn't elaborate. Is anyone here aware of what could be wrong or missing? Are there detent springs or balls that were removed so it wouldn't go into float, or is it something more sinister? He is not on the net so I got rooked into this research project! Thanks in advance for any info!!
Jim Becker
05-29-2005 19:25:15
 Re: IH240 3-point in reply to North1, 05-29-2005 17:33:40
What mowr says will help. To totally kill the down pressure, remove a pin that is crosswise directly below the cylinder.
mowr
05-29-2005 19:03:18
It's been a while since I had a 240 but...mine came from the factory with a 2-point hitch and had the (much later) 3-pt. conversion. This is probably what he has. On mine, all I had to do to get it to 'float' was remove a pin from each lower lift sleave so it could pivot on it's (front) drawpin.
