544 SLOW 3 POINT!!!!
Ponchobro
06-02-2005 14:32:04
Hello, I just looked at a 544 IH. It had a rear blade on the 3 point hitch. I pulled the lever to lift it and it would not move until the engine was reved up. It came off the ground a few inch's until I drove it then it came all the way up. Any thought,s week hydro pump??? Thanks
ed1
06-03-2005 10:33:02
 Re: 544 SLOW 3 POINT!!!! in reply to Ponchobro, 06-02-2005 14:32:04
Also look to see if the gasket on the cover was sealing properly. Any leak and the pump will pull in air.
Filter change and new gasket should correct.
If youdon't know the history of the tractor a hytran change might also be a good idea. I think it's 18 gallons or so. I'd also use hytran if you think their is water in it as it has better water retension and anti-rust properties that the others. A second choice would be JD's hygard. I'd stick away from the others. Hytran is a special blend designed by IH for their Hydro tractors. They made it so good that they use it in all their products.
Lance R.
06-02-2005 16:20:34
I had the same problem with my 560. It turned out to be dirty hyraulic fluid. I changed the fluid and filters and it works fine. If you don't change the fluid and filter it will only get worse. There was also water in my fluid. I would try this first before I would consider the pump itself.
