F-12/14 Hysler overdrive ?
Bobcat
06-05-2005 17:43:28
On the add on 2 speed overdrive the input shaft has a 6 spline 1 3/8" shaft. My original input shaft has a keyway. Does the F-14 input shaft use a keyway or a 6 spline? Does anyone have a idea on what I could use as a input connector for this? I am hoping one of You has been through this and found a solution. Thanks!
ET
06-07-2005 06:32:51
 Re: F-12/14 Hysler overdrive ? in reply to Bobcat, 06-05-2005 17:43:28
My guess is that the yoke you need came with the overdive and was mad by hysler. I think it should be the same on a F12 or F14 unit. Having one made may be your only option.
Jason(ma)
06-06-2005 19:58:29
I had to have one fabicated for my F-12. I took a 1 3/8 6 spline coupler and my original yoke to a machine shop friend.
ET
06-06-2005 09:20:53
I have a F12 with a hysler overdrive in it. I did not install it but have heard some stories from the oldtimers looking it over. I believe the transmission input shaft with the bevel gear on it and the bearing quill it mounts in are removed and the overdrive unit bolts to the front of the transmission in place of the bearing quill. The overdrive has its own bevel gear. There is only one of the flex couplers left in the drive shaft in front of the overdrive. The bevel gear is diffrent between the F12 and F14, it may have hielical cut teeth on the F14 unit.
Delbert in Lincoln
06-06-2005 11:20:51
 Re: F-12/14 Hysler overdrive ? in reply to ET, 06-06-2005 09:20:53
I installed a Hysler overdrive in a 37 F-12, about 50 years ago. The front gear and input shaft came out of the tractor, and the overdrive bolted into its place. I believe there was some shims supplied to get the bevel gears set together right. If I rember correctlly, the 1st overdrive position was a little faster then 3rd. It definetly made it a better tractor, but we were in the hills, and it did not have the power to make a hill in 3rd overdrive with a wagon load of ear corn. The pulley and PTO run too fast in overdrive to be of any use. Delbert from Lincoln
Bobcat
06-06-2005 13:35:45
 Re: F-12/14 Hysler overdrive ? in reply to Delbert in Lincoln, 06-06-2005 11:20:51
I have the unit installed in the tranmission that went fine. What I am asking about is the front yoke that connects the engine to the overdrive unit. On my original non-overdrive yoke, a keyway attaches the yoke to the shaft. Now on the Hiesler unit the input shaft has a 6 splined 1 3/8" shaft. So my original yoke will not fit onto the Hiesler overdrive. I am looking for help here on locating a yoke that fits onto this input shaft. I was wondering if I will have to fabricate this yoke of if a F-14 yoke is different that a F-12"s? The overdrive has F-14 written on it! Thanks for Your help!
Jim Becker
06-06-2005 20:02:09
 Re: F-12/14 Hysler overdrive ? in reply to Bobcat, 06-06-2005 13:35:45
The F-12 and F-14 overdrives were different, but I don't know how they differed. Since the back fit in, maybe the yoke is the difference.
By the way, they were available in 2 different ratios, the same 2 ratios for F-12 and F-14.
