Farmall Super M idles only.
NorthstarFarmer
06-13-2005 19:20:31
My Farmall Super M starts easily and runs well for about five minutes. When under a load, the engine surges, dies, surges, dies, etc. I cleaned the fuel tank and bowl and blew all the lines with compressed air. I tried a new vented gas cap to no avail. I gave it a complete tune-up, but have not cured the problem. There seems to be a "popping" in the exhaust. Burnt valves or bad carb? Should I check the compression and if so, what should the readings be?
El Toro
06-14-2005 06:24:11
 Re: Farmall Super M idles only. in reply to NorthstarFarmer, 06-13-2005 19:20:31
Open the main adjusting screw ccw one full turn
on the carburetor. Check the valve lash. I would adjust them to .020" cold until you get the engine to run ok, then readjust them to .017" hot.
Hal
Hayfarmer
06-13-2005 21:06:58
There is also a screen in the inlet from the fuel line to the carb that could be dirty
old
06-13-2005 19:30:53
Sounds like you need to do a carb rebuild. Back fire to me means its running very lean which is a carb problem
NorthstarFarmer
06-13-2005 19:43:35
 Re: Farmall Super M idles only. in reply to old, 06-13-2005 19:30:53
I was hoping it needed only a carb rebuild. Why does the thing seem to run fine for 10 minutes or so? (basically until it gets warmed up)
old
06-13-2005 20:43:18
 Re: Farmall Super M idles only. in reply to NorthstarFarmer, 06-13-2005 19:43:35
The carb holds just about that much gas, then if its not getting enough gas it dies. Funny how it will run that long on just a crab full of gas but thats how they are.
Nat
06-14-2005 06:25:37
 Re: Farmall Super M idles only. in reply to old, 06-13-2005 20:43:18
Yup, the bowl fills back up while the tractor sits.
