44A mower
cub driver
06-17-2005 21:44:54
I am looking for a new belt for the mower deck, it's the one that goes around the three pulleys and idler under the cover can anybody give me a jobber part number? Where can i get bearings and blades?
El Toro
06-18-2005 16:36:59
 Re: 44A mower in reply to cub driver, 06-17-2005 21:44:54
If those bearings have a number on them, your local NAPA store can probably cross-reference them. Hal
bermuda ken
06-18-2005 09:02:20
These parts are listed online at:
www.cngco.com/cc_gnrl_part5.html
The spindle bearings are only $63each, not $100 + as other places want you to buy a rework kit.
El Toro
06-18-2005 04:38:23
The IH dealer in Delaware has all the parts.
The belt is $25.00. blades $13.49 each and they said you need to buy the spindles at $111.00 each.
Their toll free number is 1-800-341-4028. Hal
cub driver
06-18-2005 08:26:39
 Re: 44A mower in reply to El Toro, 06-18-2005 04:38:23
Thanks for the help now I'll be able to start fixing it up and get back to mowing. Walt
El Toro
06-18-2005 03:53:15
Have you tried your local IH dealer? Is there
any numbers on the belt? Your local auto parts store that sells Gates belts may have a belt. Gates sells the green striped belts that are designed for being engaged and disengaged. The bearings are probably available there too. You need to take the numbers or the old bearings with
you. I'll call our local IH dealer later this morning and will post back if they have anything.
What are the dimensions of the blades and hole size? Hal
JLE
06-18-2005 03:53:08
Cub Cadet Dealer should have it all.
