oil seals
hfarmall
06-21-2005 19:41:34
Hi, How hard is it to remove the oil seals that are around the clutch and brake shaft on each side of the tractor. I'm going to put a new bushing in the clutch pedal. Is there any secrets to this operation. thanks, hfarmall
iester
06-21-2005 20:20:30
 Re: oil seals in reply to hfarmall, 06-21-2005 19:41:34
Don't no your model...But on mine remove petals & keyway's, pull rod out,then use seal puller...I had rod built up and reground lot's of were there
