340 farmall
Gary Cole
06-24-2005 16:21:43
My Brother has a 340 gas and it has been missing after a few minutes. Got hot and now when you pull the oil dip stick out its blowing out oil out of the dip stick hole. What all is wrong? Thanks
El Toro
06-24-2005 16:52:05
 Re: 340 farmall in reply to Gary Cole, 06-24-2005 16:21:43
Hi Gary, I think you have a broken piston ring
and/or a broken ring lans on the piston. This probably has cut a groove into the cylinder wall
or the sleeve if this engine has sleeves and is letting compression to blow into the crankcase.
Hal
Gary Cole
06-25-2005 03:54:00
 Re: 340 farmall in reply to El Toro, 06-24-2005 16:52:05
Thanks
