fix one problem and a new one arrives here I go ag
lekander883
07-06-2005 18:38:35
Just got my charging system all complete and working wonderful on my 1945 farmal h. I admit it put A smile on my face when I started her up tonight. I had A load of rocks and was going to move them when I lifted my freeman loader(model 11440 single stage trip bucket) and hydraulic fluid squirted out from where the arm comes out from the cylinder. there is a large bolt that threads to the end. That is all I know. I thought I better ask for help as to what I need to do and where I can find the part to fix it. ( I am hoping its just a seal ) I appreciate your help!!!
Janicholson
07-07-2005 19:15:59
 Re: fix one problem and a new one arrives here I g in reply to lekander883, 07-06-2005 18:38:35
My short answer is:
If it is a lift only, one way main cylinder, and the oil is comming from the top of the cyl where the chrome rod comes out, the cylinder is "bypassing". This means the piston is leaking oil past cups, or o-rings. If you tear it down make sure the cylinder is not scored on the bore. It should be as smooth as glass. if water was allowed into the cyl (long exposure outside) the cylinder may be pitted causing seal dammage. the only way to fix it is to hone the cylinder. (usually a good hydraulic shop can do it).
If it has been a long time sence it was uswd, and maybe left in the up position, Id check the oil in the tractor hyd. then gently/slowly lift the loader up to the top INCREMENTALLY. catching the oil in a pan. Then try the loader in use. If it seems ok use it a bunch it may just need to be operated. If it leaks down all the time, it is to the shop you will be taking it.
