Black Smoke - What Up?
Illinois Boy
07-14-2005 06:57:13
This is going to sound very naive - but here goes...
Pull the throttle back on my 350 and black smoke comes out of the exhaust. Is the carb to rich or too lean? For the life of me, I can't remember...
(I'm thinking too rich - at least fuel wise!)
I know... DUHHHHH HHHHH!
Embarrased in Illinois...
EricB
07-14-2005 11:14:39
 Re: Black Smoke - What Up? in reply to Illinois Boy, 07-14-2005 06:57:13
I like to look at the end of the exhaust pipe. If it has a lot of black carbon is running too rich (or sucking oil). If its white or light gray it's too lean. A nice charcoal grey colour is best.
Also check your pulgs. They will foul up easily if its too rich.
Rauville
07-14-2005 07:56:24
I thought I heard that it meant that a new Pope had not been chosen yet.☺ Otherwise, sounds pretty normal to me too.
Illinois Boy
07-14-2005 08:22:45
 Re: Black Smoke - What Up? in reply to Rauville, 07-14-2005 07:56:24
Rauville - now that's good!!! LOL
caseyc
07-14-2005 07:06:26
too rich if i remember right. i have my 706 gas turned up alittle and it will blow black smoke on throttle up and when i hit a hard spot and the govener kicks in.
casey
Allan in NE
07-14-2005 07:04:31
Black is rich, but if it only does it when you yank the throttle, I'd consider that more or less normal, wouldn't you?
Allan
RustyFarmall
07-14-2005 07:46:45
 Re: Black Smoke - What Up? in reply to Allan in NE, 07-14-2005 07:04:31
Yep, pretty much normal unless it is excessive. Just a little means the engine is getting enough.
Illinois Boy
07-14-2005 08:24:50
 Re: Black Smoke - What Up? in reply to RustyFarmall, 07-14-2005 07:46:45
Thanks guys - just blows black when I hit the gas - otherwise no smoke at all. Normal? Well - at least something is "normal" around my place - gives me hope!!!
Andy Martin
07-14-2005 09:28:50
 Re: Black Smoke - What Up? in reply to Illinois Boy, 07-14-2005 08:24:50
Check for black smoke when at full throttle and steady full load. Lean it out until yuou don't get the smoke at the maximum load you are pulling.
