1461 Farmall H
cashley
07-19-2005 19:18:52
My friend needs to know what cylinder is #1 to front or back of the motor.
He also needs to know how to time the magneto.
If anyone can help with these questions I'd appreciate it very much. Thank you
El Toro
07-20-2005 06:54:19
 Re: 1461 Farmall H in reply to cashley, 07-19-2005 19:18:52
You need to pull No1 plug near the radiator and hold your thumb over the plug hole. Have someone crank over the engine by hand until you feel compression. When you feel compression against your thumb stop cranking when you reach the first notch on the damper pulley. Your No1 piston is then at TDC. Then check to see where your rotor is pointing, should be at No1 plug wire in the cap. Then use the procedure that the others suggested on checking the impulse tripping. Hal
Andy Martin
07-20-2005 05:07:15
First slowly crank the engine (by hand) until the first of the two timing marks is aligned with the timing pointer. The magneto should trip just as the mark passes the pointer.
If it does not trip by the time you get to the pointer, leave the engine set at TDC (first timing mark aligned), loosen the magneto adjusting bolts, and slowly roll the top of the magneto toward the engine until it trips. Tighten it up and check it by rollong the engine over again.
If it has already tripped, loosen it and move the top away from the engine. Then crank to TDC and move the magneto in until it trips.
If the magneto has been disassembled or is from another tractor, you will have to determine TDC on No. 1 and make sure the rotor is pointed toward the No. 1 post.
old
07-19-2005 19:56:42
Front is #1 closes to the rad
