oil leak behind rims
Shadow
07-30-2005 17:09:04
I have a 1939 F-20. The problem is oil leaking from behind the rim. The oil is coming from just behind where the rim bolts on. I have looked in my service manuel, but it does not show any packing or oil seal in that location. Can someone help me out on this? Thanks!
Mike
P Backus
07-31-2005 12:22:28
 Re: oil leak behind rims in reply to Shadow, 07-30-2005 17:09:04
Front rim or rear? Any where that the turning part of a wheel hub goes into the housing, there will be some kind of a seal.
Paul
Shadow
07-31-2005 12:55:42
 Re: oil leak behind rims in reply to P Backus, 07-31-2005 12:22:28
This would be the rear rim. I thought it would have seals, but I don't see any in the service manuel.
Mike
P Backus
08-01-2005 20:49:54
 Re: oil leak behind rims in reply to Shadow, 07-31-2005 12:55:42
Geez, I"m a little out of my element with an F-20. I know that they have a "drop box", the housing that holds the bull gear and associated bearings. There should be a bearing on either side of the bull gear on the axle shaft. The bearings would be internal and there will be a seal where the axle shaft comes out of the housing. Now, I imagine that the wheel would have to come off. Beyond that I"m just not sure how the F-20 was constructed. If you"re lucky, there may be a flange that you can remove to get at the seal. There should be some way to snug up the bearings as well. Again, I imagine that it has opposing tapered roller bearings, like a wagon wheel. What does you shop manual show? What kind of manual is it? Some manuals don"t show some things because they assume that you already know all that. Thanks a lot, huh? If you jack up the tractor, does the wheel have any up-and-down play? That will cause a seal to leak. Gotta fix that before replacing the seal. I"m guessing that you can tell that it"s not leaking from anywhere else around that area? I believe that there is a gasket in between the cover and the drop box housing. How big of a leak is it?
I don"t know if I"ve helped, but maybe this gives you a place to start. Let me know what"s going on.
Paul
