300U TA
Dellbertt
08-09-2005 08:18:54
I popped the TA top cover on my 1956 300U and discovered that the throwout bearing is missing. It"s probably laying in the bottom of the case and I hope I can get it all out with a magnet. It looks like I could install a new one from the topside without removing gears or is that wishful thinking.
DWV
08-09-2005 10:00:31
 Re: 300U TA in reply to Dellbertt, 08-09-2005 08:18:54
To replace T/A clutch release bearing you need to split behind engine and remove T/A drive shaft.
Best to get instruction manual if first time.
DWV
08-09-2005 10:11:15
 Re: 300U TA in reply to DWV, 08-09-2005 10:00:31
Should have added,if I was doing that much work
I would remove center section and check or rebuild
T/A unit.If not worried about T/A you should have
direct drive without release bearing.If T/A ramp and rollers are holding it will be hard to shift though.
Dellbertt
08-09-2005 16:59:39
 Re: 300U TA in reply to DWV, 08-09-2005 10:11:15
I had a feeling I was going to have to split to get the job done. What gets me (and thankful for) is that I have pulled the TA lever several times while running and I"m surprised the release bearing fork didn"t get hung up in the pressure plate arms. Thanks for the input.
