230 transmission stuck- need advice
Jrry
08-10-2005 08:10:29
I am purchasing a farmall 230. the seller said that the transmission is locked and the rear wheels will not turn. He said two gears are engaged. Would this be a difficult problem to fix. the price is right for a parts tractor but I would like to get it operational unless this is very time consuming.
Hugh MacKay
08-10-2005 18:19:37
 Re: 230 transmission stuck- need advice in reply to Jrry, 08-10-2005 08:10:29
Jerry: Sometime these are a bit difficult to get out of gear. I find the easiest way is using an anchor vehicle and set of come alongs. You may need to apply pressure one direction, if that doesn't work try the other direction. You should be able to do this without removing transmission top. Just take off the shift lever tower. The presure one way or other will make it possible to slide those shift rails with a large screwdriver, real easy. It may also come real easy without presure, just depends on revolution on cogs when it went in two gears.
The end of gear shift lever probably needs to be built up with weld. Get it the size of notch in one rail, so it can't get from one rail to next without being at neutral. I like to build these a bit oversize, then grind until it shifts smooth.
Jrry
08-11-2005 06:07:49
 Re: 230 transmission stuck- need advice in reply to Hugh MacKay, 08-10-2005 18:19:37
thanks Hugh, this looks to be a good bit easier than I had thought. I have observed your answer to a lot of questions on this forum and I know I have learned a good bit from you and the others who help out here.
Jerry
Jrry
08-10-2005 10:24:15
thanks guys for the quick response and information
Jerry
r-cubed
08-10-2005 09:01:00
You will have to take the top off the tranny and reposition the gears by hand in neutral and also the shift collars. The shifting mechanism is probably worn out or it wouldn't get that way.
Andy Martin
08-10-2005 08:52:01
Not a big problem.
