IH 806
Mike Truster
08-13-2005 12:07:48
Have a 806 GAS, good tractor, wide front, three point, just over 4000 hrs. Looking to put a diesel in this tractor. SN is 39896 S-Y. I know you guys know what kind of options there are, how much work and money it takes, and what works best. ALL replies appreciated!
Thanks, Mike Truster
Allan in NE
08-14-2005 05:19:04
 Re: IH 806 in reply to Mike Truster, 08-13-2005 12:07:48
Hey Mike,
This is just my opinion, mind you, but I think you're gonna end up having the price of a good diesel tractor in that swap not to mention all the labor involved.
I'd sure be fer looking for a different tractor altogether iffin' it were I.
Allan
Sheepdog
08-13-2005 19:11:12
I think the best way to go is buy the diesel in the correct frame. Way too much involed in the switch. What are you using the tractor for? Look into a 1066.
Dellbertt
08-13-2005 17:04:31
why don"t you find an 806 Diesel junker for parts and start switchin. Actually if it"s a good tractor why not sell it for a good price and find a good 806D.
K.B.-826
08-13-2005 16:02:04
Takes a little work and a lot of money. Find a 361 or 407, since that is the correct block for the 806. Try to stay away from engines out of combines, they can have some seemingly minor differences that cause problems when trying to bolt it in. That will be the expensive part. You might need to get the 806 diesel frame rails, or drill two holes in each of your's for the front engine mounting bolts. I'd probably drill them. You'll need the rear engine plate and flywheel. You'll need to add a return fitting to your fuel tank. You'll need the fuel lines. You'll need the throttle linkage and tach cable. You'll need the diesel starter and another battery. You might need to relocate the exhaust pipe hole in the hood. Probably ten other small details I'm forgetting.
bollpuller
08-14-2005 09:26:26
 Re: IH 806 in reply to K.B.-826, 08-13-2005 16:02:04
got an 806 diesel wheatland that needs engine work make u a good deal on the front half. call at 580 512 3569
KRUSS
08-14-2005 13:09:11
 Re: IH 806 in reply to bollpuller, 08-14-2005 09:26:26
Around here if you had an 806 gasser you would have the only one, and probably worth a premium to somebody for that reason, although in MHO useless as t.t$ on a boar.
