one more F-20 mag question
Paul G. in Mn
08-30-2005 17:17:02
Thanks for everyones help last night. I now have spark and also got a spare mag working. The question I have is on my spare when I rotate the arm on the cover over the points in one direction it cuts the spark but on my main it will spark in either direction. I tryed a different cover over the points as well as the whole housing that has the wire that goes to the condenser. Were is this suppose to ground out when you want to shut the tractor off? Thanks once again Paul
El Toro
08-30-2005 18:16:53
 Re: one more F-20 mag question in reply to Paul G. in Mn, 08-30-2005 17:17:02
Hi Paul, What problem did you finally find with your mag? Glad you have it fixed. Hal
Paul G. in Mn
08-30-2005 18:22:08
 Re: one more F-20 mag question in reply to El Toro, 08-30-2005 18:16:53
I am really not sure what it was. I took it back apart and looked everything over but really didnt find anything. when I put it back togather and spun it with a drill it started working. Did the same thing with my spare and it started working as well.
El Toro
08-31-2005 04:12:47
 Re: one more F-20 mag question in reply to Paul G. in Mn, 08-30-2005 18:22:08
Glad you got it working ok. Hope you made a note where the rotor was pointing when you removed
the mag so the mag is in time when you install it. Hal
Paul G. in Mn
08-31-2005 13:51:10
 Re: one more F-20 mag question in reply to El Toro, 08-31-2005 04:12:47
I did make a note of were it was but if for some reason it got turned what is the timeing method on one of these? I know you adjust it at the coupler ahead of the mag and know how to get started by finding TDC but is there timeing marks? I wouldnt mind just checking it if there are marks to check to make sure it is right.
El Toro
08-31-2005 15:39:14
 Re: one more F-20 mag question in reply to Paul G. in Mn, 08-31-2005 13:51:10
You need to look for a timing mark on the flywheel
or the damper pulley. Once you locate the timing mark put some chalk on it so it's visible.
You need to remove No1 plug near the radiator and have someone handcrank it over slowly until you feel compression against your thumb, then stop
the cranking and look for that chalk mark. Once you locate the chalk mark keep cranking the engine until the chalk mark is aligned with the pointer. You could use a big handle screwdriver after you feel compression by placing it in the
plug hole and watch very closely until the screwdriver stops rising. You don't want to drop
that into the cylinder. This is TDC for No1 piston. Your timing marks should be aligned too. Crank the engine very slow after you feel compression. Don't move the engine now.
Rotate the rotor on the mag to the No1 position on the cap and install on the tractor. The rotor should point to No1 in the cap, if not you need to pull the mag and reinstall until it is at No1. Don't forget to remove the screwdriver. Reinstall plug and see if the engine will start.
Hal
Paul G. in Mn
08-31-2005 15:45:14
 Re: one more F-20 mag question in reply to El Toro, 08-31-2005 15:39:14
ok thanks I wasnt sure if there was timeing marks or not. Do you know were the timeing should be set? I have a timing light that I can set advance in.
El Toro
08-31-2005 15:52:23
 Re: one more F-20 mag question in reply to Paul G. in Mn, 08-31-2005 15:45:14
I'm not sure, it could be TDC. I don't have a manual for F-20. Once you get it running you can post for info on here. Someone either knows or has manual that has that info in it. If you don't have a electric starter on your tractor, you can use the battery in your car to power the light. Let us know if it starts. Hal
Paul G. in Mn
08-31-2005 15:55:38
 Re: one more F-20 mag question in reply to El Toro, 08-31-2005 15:52:23
Thanks alot, I did install electric start on this one. I will start a new thread and ask what the timeing should be set at. Thanks for all your help Paul
Nebraska Cowman
08-30-2005 17:33:31
the rotating breaker part contacts a peg. You can see the peg here right inline with the notch the cover sets in.
third party image
Nebraska Cowman
08-30-2005 17:35:33
 Re: one more F-20 mag question in reply to Nebraska Cowman, 08-30-2005 17:33:31
here is another pic with it almost touching
third party image
Paul G. in Mn
08-30-2005 17:50:25
 Re: one more F-20 mag question in reply to Nebraska Cowman, 08-30-2005 17:35:33
Hey thanks, the arm on the set of points I was useing was bent just enough to miss the contact. both are working great now.
Nebraska Cowman
08-30-2005 17:52:53
 Re: one more F-20 mag question in reply to Paul G. in Mn, 08-30-2005 17:50:25
cool, glad you found it.
