Farmall Starter Configuration
MACE
09-07-2005 17:15:09
Did the early Farmall A's have a starter without a switch mounted on top of the starter (integral switch)? The reason I ask is my 1941 has a starter with no switch and I have seen other Farmall A starters without switches mounted on top of them. What should my 1941 Farmall A S#48529 have on it? I have the parts manual, but there is not an exact detail that I know of in the manual that shows the proper setup. I could use a detailed close up picture if anyone has one.
Thanks,
MACE
gene b
09-08-2005 03:14:14
 Re: Farmall Starter Configuration in reply to MACE, 09-07-2005 17:15:09
You need to get one for an A or B with the copper bar on the drive end with the two threaded holes so the sw will mount and the foot operated rod will push to enguage. One for a C will have the bar on the brush end and then the sw will mount backwards and have to be pulled.
banjo
09-08-2005 20:53:49
 Re: Farmall Starter Configuration in reply to gene b, 09-08-2005 03:14:14
My super A has the rod you pull to start.oposite side of choke rod. did i read your post wrong?
Jim Becker
09-07-2005 21:26:33
They all had the switch directly on the starter. Your has been changed.
MACE
09-08-2005 05:10:55
 Re: Farmall Starter Configuration in reply to Jim Becker, 09-07-2005 21:26:33
That is exactly what I wanted to know. My starter does not have the mounting holes for the switch. It was on the tractor when I got it and I am sure someone had the wrong starter on there. So what I need to find out now is if the correct starter switch arrangement had a starter rod that is a pull by hand type or if it is a foot activated type setup.
Thank You,
MACE
Jim Becker
09-08-2005 22:21:23
 Re: Farmall Starter Configuration in reply to MACE, 09-08-2005 05:10:55
Like gene b said, the A and B used a switch mounted for a rod pushed with your foot. The Super A and C switch mounted the other way for a pull rod.
gene b
09-08-2005 10:48:03
Read my post then you will know the correct starter to get.
MACE
09-09-2005 04:41:57
 Re: Farmall Starter Configuration in reply to gene b, 09-08-2005 10:48:03
Thank Y"all for your help...
MACE
