Farmall 300 kit (Basket case)
willyz
09-11-2005 05:30:03
I was putting together my 300 after replacing the rollers, pin, springs,pressure plate, etc. in the TA and replacing the clutch and pressure plate for the transmission. I put some long bolts in the bell housing to join the halfs together. I measured the gap top and bottom on both sides to be sure it was going together straight. After the splines started to come together, I turned the PTO shaft to make sure they meshed. Everthing seemed fine at even a 1/8" gap but when I tightened them together there seemed to be a bind. Anyone have an idea what might have happened. I am a recent convert from the green and yellow religion and don't have much experience with these red machines.
MN Scott
09-11-2005 10:30:53
 Re: Farmall 300 kit (Basket case) in reply to willyz, 09-11-2005 05:30:03
The factory service manual recomneds that you put the pressure plate and disc on the transmission shaft before you join the tractor. When you get it together you bolt the plate to the flywheel by working thru the cover underneth the tractor clutch housing. This works great and you do not risk bending something. I think you should pull it back apart to make sure you did'nt damage something by forcing it together.
ejr-IA.
09-11-2005 09:42:55
Their are two shafts you have to line up trans. and PTO.
