Kind/Brand of Primer to use after Phosphoric Acid
Dave in CT
09-13-2005 07:00:03
I'm painting some half-rusted and fully rusted metal. I've been removing the majority of the rust with a twisted wire brush on a grinder and then treating the metal with Must-for-Rust (phosphoric acid). What type or brand of primer have folks had success with after this type of treatment? Also, the resulting surface after this treatment can have glossy spots. Do I need to break up that gloss by light sanding or will that just be wearing away the protective residue of the Must-for-Rust?
CNKS
09-13-2005 07:12:02
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to Dave in CT, 09-13-2005 07:00:03
What I usually do with such products is use a scotchbrite pad, or similar product and remove as much of the residue as possible. I then treat with wax and grease remover -- I use PPG DX330. I also use PPG Omni MP 170 epoxy primer. Whatever you do don't use etch primer after a phosphoric acid treatment -- there is the possibility of too much acid. I have not yet painted over "Must for Rust", although there are some parts ready to paint. Thus far I have only used Picklex 20, I don't think there is much difference except for cost, but I don't know the formulations -- My guess is you will be fine. As far as breaking up the finish, if you paint it within a reasonable amount of time after scuffing or sanding, it shouldn't be a problem, as the epoxy seals the metal and prevents moisture from getting in. That is one advantage of epoxy primers, they are waterproof, other primers aren't.
Dave in CT
09-13-2005 07:37:39
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to CNKS, 09-13-2005 07:12:02
Do these primers have hardener - i.e.: require the forced air breathing mask for safe application? My occasional painting requirements are to get the metal protected and looking decent, not show-ready, so I'm avoiding major investments. On the other hand, if someone tells me such systems mean the difference between painting again in five years vs. thirty, it would be something I'd consider.
CNKS
09-13-2005 10:56:34
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to Dave in CT, 09-13-2005 07:37:39
Tim is correct, you only need a charcoal mask for most epoxy primers, just be sure to check the one you use. Omni MP 170 also has the 3 day window, you have to scuff and reapply (not necessarily sand) after the 3 days. More expensive ones have longer windows -- up to a week, but as far as I know you can't store any parts for any length of time without reapplying.
Dave in CT
09-13-2005 11:53:41
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to CNKS, 09-13-2005 10:56:34
Just talked to the local PPG auto parts store - only place nearby that sells the stuff. The guy I spoke to said I had to use the hardener with the MP 170 or else it would never dry. The price for the primer + hardener was eighty-something dollars for a gallon. Does this sound right as far as use of the hardener and the price? As far as I'm concerned, any time I start using the hardener, I need the forced air mask.
CNKS
09-13-2005 12:28:44
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to Dave in CT, 09-13-2005 11:53:41
You can go to the PPG web site and look up the MSDS. I assure you that the catalyst for MP 170 does not contain isocyanates. I paid $77 a couple of years ago, so the price is in line. I just tried the web site and the MSDS part is down, go figure. Again the hardener does not contain iso's, if it did I would be dead. That is the only part of my painting that I don't use my supplied air system. I am positive. Epoxy hardeners are the only ones I know of that don't.
Dave in CT
09-13-2005 12:48:25
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to CNKS, 09-13-2005 12:28:44
Thanks CNKS. I'll go with your recomendations.
Tim...Ok
09-13-2005 08:08:59
Dave, Most,if not all of the epoxy primers only require a charcoal mask..I've been using the Nason..only thing i don't like about it is the relatively short window you have for getting the topcoat sprayed..on mine it's 3 days..go over that and your supposed to scuff the epoxy,spray another coat of it,then get your topcoat on within that 3 day window... kinda tight window for a part timer like myself..I'd like to be able to clean and prime parts at my leisure,then have a painting day to put the color on..
Tim
Tim
CNKS
09-13-2005 10:59:12
 Re: Kind/Brand of Primer to use after Phosphoric A in reply to Tim...Ok, 09-13-2005 08:08:59
But, you can use Picklex type products and keep them from rusting indefinitely, then prime and paint.
