Three Point Hitch for Farmall H
Scott Swanson
09-14-2005 11:17:51
I recently saw a bunch of fun three point stuff at the Minnesota State fair and was wondering if I could use the stuff on my H if I tossed a Saginaw Three point hitch on it.
I saw plows, blades, cutters, mowers, rakes, cement mixers, etc. The list goes on like a Martha Recipe.
Any feelings or facts on this out there?
Thanks,
Scott
Easy
09-14-2005 23:30:39
 Re: Three Point Hitch for Farmall H in reply to Scott Swanson, 09-14-2005 11:17:51
I have a saginaw hitch on my H, and it works great. I like the fact that it has 2 cylinders, is very heavy duty, and has adjustment screws on both lift arms. And by pulling 2 pins, it will "float" up, makes it easier on a bush hog. I use mine all the time with a post hole digger, blade and bush hog. Best tractor money I ever spent. Easy.
riverbend
09-14-2005 16:26:26
I believe that the Saginaw ( I have a different brand)is the best of the aftermarket three points for an H. It lets you keep the original drawbar. Some aftermarket drawbars are about 2/3 as heavy as the originals.
If I pick up more than about 500 pounds with the three point, the front end gets a little light.
26Red
09-14-2005 11:31:03
Got a saginaw on my Grandpa's H and my 300. Spendy but worth it. We have cultivators, 6ft disk, brush mower, pallet forks, and a rear blade that we use between the two tractors. The H has a pto drive hyd. pump that supports the loader, I just added another valve to run the 3-pt hitch. I would like to relocate pto pump to run off the belt pulley, then I could run the brush hog behind the tractor. You could easily plumb the belly pump to a remote valve for the 3 point hitch, if you wanted down pressure for the 3 pt, otherwise, a one way cylinder is okay too.
26Red
09-14-2005 11:31:00
ChrisL
09-15-2005 08:30:53
 Re: Three Point Hitch for Farmall H in reply to 26Red, 09-14-2005 11:31:00
My H has a trip loader, I would also like to add the saginaw hitch, but if looks like I would havbe to remove the loader to mount as it mounts at the same location ...maybe I need to contact saginaw to clarifiy.
