6-volt generator
baler 46
09-17-2005 16:59:13
Hi just wonering witch pulley is the right one for my 50 farmall h.There are two different sizes pulley are 3 1/4 or4 inch .I have two gen each have a different size pulley on them.Does this mean it for different tractors the number on the generator is the same 1101355 with a relay box on top. thanks
P Backus
09-17-2005 18:25:55
 Re: 6-volt generator in reply to baler 46, 09-17-2005 16:59:13
Could it be that one of your generators is for and H andthe other for an M or something similar? The size of the pulley would have a relationship to the size of the crankshaft pulley driving it. I don"t know for sure, but it could be that an M pulley is a bit bigger.
Do you have the 4 position light switch or the 3 position light switch? The thing you called a relay box on top of the generator is probably a cutout, used on the older style generators. The newer ones had a voltage regulator mounted elsewhere (by the steering column). I"m not sure of this either, but I think that by "50 they were using the regulator with the 3 position switch. The 4 pos switch was used with the cutout style.
Paul
