Farmall Super C Worth the price
Getting Started
09-21-2005 15:21:04
I recently located 2 farmall super c's. However 1 is only a parts tractor with no sheetmetal that is usable and only 1 rear tire on the tractor and both fronts are lying on the ground beside it, that has been sitting at least 18 years and stuck. The other has all 4 tires but 1 rear is bad. Not running but free with the head off. However they have the head and has been sitting for 2 years. However there is rust in the cylinders. Is both tractors worth $500 dollars? Thanks for the help in advance.
Peabody
09-21-2005 20:26:23
 Re: Farmall Super C Worth the price in reply to Getting Started, 09-21-2005 15:21:04
If you don't want them, let me know where they are.
MM_TX
09-21-2005 20:10:59
My better half will lets me spend $200-$500 on stuff not too much hastle but $1500 and Ive got to really put the reality check to it. Iv'e got a $300 Super C thats at about $2000 and Its almost real nice and a $800 M I added 3pt, live hydrolics & wide front so I could put a loader on it (still needs power stearing) at about $2000 in work cloths. I probably could have bought eather for less than I'v got in them, but around here their's not a lot to choose from. I know if I told my wife I was going to spend $4000-$5000 on old Farmalls she would'a cried. I've got my eye on a dead complete F-14 & 2 F-20s I know will be "cheap". New tires make them look real good. Good luck
CNKS
09-21-2005 17:37:17
$250 apiece?, they are probably worth the money. But, remember, parts tractor or not you are going to put a pile of money into the one you fix up. As long as you understand that, you will be ok. Make sure that neither block is cracked -- if so, although they can be fixed, walk away as there are better tractors to be found.
fm
09-22-2005 18:11:56
 Re: Farmall Super C Worth the price in reply to CNKS, 09-21-2005 17:37:17
I really think that is a good deal but like CNKS says you will spend alot of money on them, I bought a farmall 350 complete for $200 and $4500 later and sill not done but I wont have to do anything to it for awhile but if you do buy them, good luck to you and have fun.
El Toro
09-21-2005 16:00:53
I think it's a bargain at $500.00 for both tractors. If the blocks and heads aren't cracked
you can probably restore both tractors. Keep one for a parts tractor or sell one. Hal
