Hey Jim Allen! D-358 EGT
K.B.-826
09-24-2005 20:14:11
Jim, according to the manual, a 886 with a 358 running at rated speed full load has a "normal expected" EGT range of 1020-1220 degrees F. Where it falls in this range depends on several factors, including ambient temp and elevation above sea level. EGT will go up 2 degrees for every 1 degree increase in ambient temp, and will go up 20 degrees per 1000-foot increase in elevation above sea level. The manual says to run the engine at rated speed full load on a hot day, note what the pyro reads, and set the alarm 100 degrees above this temp (your pyro probably has a pointer that can be adjusted to indicate max EGT). The manual goes on to say to never exceed 1420 degrees, as this will crack the head. It also says that a hot engine should be idled until the EGT cools to 550 degrees before it is shut down.
Jim Allen
09-25-2005 06:08:20
 Re: Hey Jim Allen! D-358 EGT in reply to K.B.-826, 09-24-2005 20:14:11
K.B.- Thanks. This is useful info. I'll keep you posted as to what it does. The gauge I have is a leftover from a Banks kit on one of my trucks. no alarm. I'll just have to watch it carefully. Thanks again!
