gear shift
SAM BROWN
09-28-2005 06:04:52
I HAVE A FARMALL 100. ALL GEARS WORK FINE.EXCEPT WHEN PUT IN REVERSE ,THEN TO GO FORWARD THE GEARS GET CROSSED IN REVERSE. SET AND SHIFT THROUGH THE GEARS A FEW TIMES THEN IT WILL UNCROSS. HELP WHAT IS WRONG.
SAM BROWN
09-30-2005 14:20:18
 Re: gear shift in reply to SAM BROWN, 09-28-2005 06:04:52
Thanks Aces and RustyFarmall.Can you give me the diameter of the build up?
Aces
09-28-2005 06:13:45
Sam sounds like the end of the shaft lever is warn and needs welded up and reground.
RustyFarmall
09-28-2005 06:43:22
 Re: gear shift in reply to Aces, 09-28-2005 06:13:45
That would be my first thought. When the end of the lever gets worn down it can actually lose contact with the shift rails, and cause the exact problem you mention.
