Help H starter button sparks
IHCarl66
09-29-2005 18:37:05
When I push the starter button it sparks at the steering column I can"t find anything that would cause this Could the starter button itself be arching out on steering column?
jimmorlan
09-30-2005 17:52:39
 Re: Help H starter button sparks in reply to IHCarl66, 09-29-2005 18:37:05
Had the same problem. After checking it out, I found that the terminal on the Starter cable was touching the housing around the switch. When I pushed on the switch button it would short the battery to positive ground and shoot sparks out what I thought was the swicth. I simply loosened the nut and readjusted the cable and now it is fine.
Farmall Ed
09-30-2005 05:51:35
Most likely a bad starter switch, I have had two that did the same, New starter switch fixed both. Ed
RustyFarmall
09-30-2005 04:51:58
Most likely corroded and or loose connections. Take the cables off and clean the ends up with sandpaper so that they are bright and shiny, do the same thing to the mounting stud where the cables attach, and the reinstall, get the nuts good and tight, but do not overtighten.
CNKS
09-29-2005 19:23:11
Worn wiring, probably. Pull it off and rewire.
