IH 140 Carburetor Problem
Steve17368
10-04-2005 17:01:10
I'm restoring a late model IH 140, which is equipped with a Zenith carburetor. The upper body of the carb has a crudely repaired break in it that leaks. Also, the threads are stripped at the fuel line fitting intake. It leaks there also. I would like to replace the carb.
I would like some advice on a replacement. Are rebuilt Zenith carbs available that have high quality rebuild parts in it? I've heard that some of the rebuild kits (for the Cub) are of poor quality. Also, does anyone have experience with the after-market carbs that are available from various sources?
Your comments are appreciated. Thanks, Steve
RustyFarmall
10-05-2005 04:43:31
 Re: IH 140 Carburetor Problem in reply to Steve17368, 10-04-2005 17:01:10
Steve, is there a number on your carb? I may have one that I could rebuild for you. High quality rebuild kits are available, but I am having a little trouble finding a dealer that has them. Brand new aftermarket replacements are also available, but I am not too sure of the quality on those, they may be OK. In any event, if your carb is broken, which it sounds like it is, you are at least going to need an unbroken top part.
