Spindle Bearing ?
iester
10-15-2005 16:59:03
I"m replacing bearing and didn"t note which way the bearing was turned.Does the roller side face down towards the hub or up towards top of spindle?
billde
10-15-2005 17:51:14
 Re: Spindle Bearing ? in reply to iester, 10-15-2005 16:59:03
I assume you mean the thrust bearing on the vertical shaft of the spindle? Rollers normally face up.
iester
10-15-2005 17:59:46
 Re: Spindle Bearing ? in reply to billde, 10-15-2005 17:51:14
Sorry,I guess I didn't leave enough information.It is a spindle thrust bearing,on a wide front.
lee
10-15-2005 17:32:13
huh?
Janicholson
10-15-2005 17:41:55
 Re: Spindle Bearing ? in reply to lee, 10-15-2005 17:32:13
Look below on this or P2 for wheel bearing discussion.
JimN
iester
10-15-2005 17:44:59
 Re: Spindle Bearing ? in reply to Janicholson, 10-15-2005 17:41:55
Spindle bearing.
iester
10-15-2005 17:41:18
It's a 350 utility tractor wide front.I'm replacing spindle bearing.Which way does the bearing turn?
Janicholson
10-15-2005 17:55:55
 Re: Spindle Bearing ? in reply to iester, 10-15-2005 17:41:18
Gotcha now, The thrust bearing (from what I remember) has hardened steel washer, then rollers and cage, then another hardened steel washer. They don't like iron. Could be wrong, Our 350 has never hadem off but the neighbor's did.
JimN
stu in njo
10-15-2005 17:51:05
Which way is the tractor going. youre ? makes no cents. Stu
