Farmall B bearing replacement
Dave H (MI)
10-18-2005 13:57:56
Ran into a hitch this afternoon. On the inboard bearing, the directions say to install the inboard cone in the hub (the cup is already in there to receive it) and then install the seal retainer (which looks a lot like a metal cookie cutter in the shape of a circle) in the hub until the outer flange contacts the hub. No way is this going to happen. The height of the seal retainer is about a quarter inch more than the space left in the hub after the cup is fully seated. In short, the seal retainer is about a quarter inch hanging out of the hub when I get it in as far as it goes. These instructions are terrible....don't even mention the washers. Can anyone tell me what the heck is up here with this seal retainer? Seems like the way I read it the seal retainer should go all the way into the hub and the flange go over the outer lip of the inboard side of the hub. Could use a quick hand if anyone knows.
Dave
Dave H (MI)
10-18-2005 14:01:21
 Re: Farmall B bearing replacement in reply to Dave H (MI), 10-18-2005 13:57:56
Look at that! I stuttered. Found out the problem. Compared it to the OTHER hub and it would appear that the two little idiots (they know who they are) who sold this big idiot (I know who I am) the tractor ran the darn thing with the bad bearing so long that it actually wore the inboard side of the hub down a full quarter of an inch. Now I will be looking for a new hub AND I have the makings of a really nice boat anchor. Time to start hunting...
Tom F
10-18-2005 14:11:40
 Re: Farmall B bearing replacement in reply to Dave H (MI), 10-18-2005 14:01:21
those wheel bearings easily fit into the most neglected category!
Janicholson
10-19-2005 06:32:02
 Re: Farmall B bearing replacement in reply to Tom F, 10-18-2005 14:11:40
That is a bit of grief. If you need the unit for work, and the seal will stay in place, I'd use it till I got another hub.
JimN
