454 remotes
Galen
10-27-2005 19:10:41
I have a 1971 454. I am running a loader on it, with a separate spool valve. There is also a set of remotes on the rear of the tractor. Anyone know how to operate this remote? Wish there was a cheap manual out there that I could afford 8^).
jpsep
10-28-2005 08:04:36
 Re: 454 remotes in reply to Galen, 10-27-2005 19:10:41
Go to your local case ih dealer and buy a power beyond block for the loader. This will allow you to use your remots and loader together. The service manager wil have info on hooking this up. It is not much trouble to do.
JB2
10-27-2005 21:18:11
Hi Galen, on my brother's 454 the remote on the rear is controlled by the lever behind your right leg when sitting on the seat. Comes out of the panel below the 3 pt hitch controls and above the differential lock lever at your right heel.
JB2
Joe Bloggs
10-27-2005 20:08:40
I have the same tractor. I did not have any hoses at ther back. I did install a remote valve and hoses to work the dozer blade I fitted to the front. the books I have show nothing on this subject and I have 6 books.let me know what you have and I will do my best to help you.
how many remote valves do you have. are they hooked up to any thing.
Galen
10-28-2005 01:49:12
 Re: 454 remotes in reply to Joe Bloggs, 10-27-2005 20:08:40
I have one set of remotes on the rear of the tractor. They are hooked up to the pump, but I don't have any other levers beside the PTO/draft control. There are two slots for levers, but no levers. Might have to post a pic in the morning.
JB2
10-28-2005 12:13:57
 Re: 454 remotes in reply to Galen, 10-28-2005 01:49:12
Hi Galen, lever should be behind your right heel.
Always had to reach down to activate but most people put an extension on the lever to bring it up by 3pt lever.
JB2
Tim...Ok
10-28-2005 04:30:01
Galen,
I could be wrong,but seems like I read that the knob under the front of the seat redirected the hydraulics to the remote and then used the 3pt. lift control?? I'd like to find one of the remote retrofit kits for my 424 since it didn't come with a remote..
Tim
