Farmall M governor adjustment Screw?
Junkman10
10-27-2005 23:32:40
I bought a lot of parts off neighbor who used to work on tractors. I was looking at a governor that I purchased and noticed it had a adjustment screw and lock nut coming through rear of housing, toward the the block side. Housing has IHC cast in bottom. Has 2 weights, no linkage to carb. I Noticed none of my M's had this screw. Is this a aftermarket modification or is this off of a different IH engine? I can send pics if needed.
DWV
10-28-2005 05:53:08
 Re: Farmall M governor adjustment Screw? in reply to Junkman10, 10-27-2005 23:32:40
Used on some power units to control hunting where
a steady speed was wanted.See them on tractors ever once in while but don't know if they originaly came that way.
MagMan
10-28-2005 04:21:24
I am not sure where it comes from but the one I am using on my H has the same thing. It is not an adjustment but rather a spring stop that when the govener goes all the way one way or the other I cant remember it hits the spring and stops instead of the housing. Maybe it was something to help in wear, or Hunting. If you find out for sure I would be interested in knowing my self. JON
