ID plate question
Ted Parsons
11-01-2005 13:28:21
What does the "DS" stand for on the ID plate of a Super MTA.
Teddy H Parsons
11-02-2005 13:53:07
 Re: ID plate question in reply to Ted Parsons, 11-01-2005 13:28:21
I asked what DS stands for, after the serial number? Which is 62268 DS. Thanks.
CNKS
11-02-2005 17:55:00
 Re: ID plate question in reply to Teddy H Parsons, 11-02-2005 13:53:07
And, I told you!
ted parsons
11-03-2005 17:29:52
 Re: ID plate question in reply to CNKS, 11-02-2005 17:55:00
You say you told me, where do I find the answer?
CNKS
11-03-2005 17:39:04
 Re: ID plate question in reply to ted parsons, 11-03-2005 17:29:52
(Very calmly)--IH used suffixes after the serial mumber to indicate how the tractor was equipped. Separate the D and the S. As I said D means a 5000 ft altitude engine, generally that meant higher compression pistons to make up for the thinner atmosphere. S means your tractor has a torque amplifier "with provision for" 540 rpm independent pto. An R would be a transmission driven PTO. The S on your tractor means if your tractor has a PTO, it is live.
CNKS
11-01-2005 13:56:50
D is 5000 ft altitude pistons, etc; S is TA with provision for 540 rpm pto.
