Narrowed Down
James.01
11-09-2005 19:25:23
First off thanks for everyones help so far. I have narrowed the problem on my h down to the #1 and 3 piston.Every thing else works good. now the question is what is the best way to go about removing the 2 pistons with minimal damage to the engine.
Also i was wondering how to remove the sleeves if i have to.
El Toro
11-10-2005 06:07:03
 Re: Narrowed Down in reply to James.01, 11-09-2005 19:25:23
I would agree with Slappy on doing all 4. Hal
Slappy
11-10-2005 05:10:31
The easiest thing will be to pull the head, drop the oil pan, pull the bearing caps and push the pistons out through the top. If you have a ridge, you may need to buy/rent a ridge reamer (measure the cylinder diameter at the ridge first - it can be handy later).
I didn't read your last post, and so am not familiar with the original problem. That being said, I don't think I would recommend replacing/reparing just two of the pistons. I would suggest that whatever you do to #1 and #3, you also do to #2 and #4.
