330U Stops Running
Tweeter
11-13-2005 13:26:47
I got my wiring finished on my 330U and everything works there. I got to start it up today but it dies after about 1 or2 minutes. It is hard starting unless I place my hand over the intake and keep it there. While holding my hand on top of the intake I cant rev it or it will die out. My carb is dripping gas which i was told before that the float is probably stuck up. I took the carb off and float was moving freely. I didnt have time to put it back on and test it again. Should i rebuild the carb with a kit and also a NEW float? It is a Zenith carb with the drain plug out front.
Andrew Z
11-13-2005 13:35:32
 Re: 330U Stops Running in reply to Tweeter, 11-13-2005 13:26:47
Make sure to check the needle valave thats were alot of debris get caught up. And check the float setting out while your there. Andrew
