Float Adjustment
Tweeter
11-14-2005 10:25:02
What should the setting be for the float on a IH 330 Utility with a Zenith carb?
Uncle
11-14-2005 19:06:27
 Re: Float Adjustment in reply to Tweeter, 11-14-2005 10:25:02
I don't have the exact setting but I can tell you how I have set every carb I have built.
Install new needle and seat, float and pin. Hold the assembled top in your hand with the float facing up. The part line on the float should be perfectly level with the carb gasket surface.
You will be set every time.
