question about hitch for implements
Raymond Vanderv
11-15-2005 10:20:43
I purchased a 1959, 35 hp, Farmall row crop gas tractor with a draw bar hitch only. I understand it can not use a three point hitch because there is no place for a 3-8 cylnder on the back of this tractor. Do I still need to have a two point hitch to be able to use implements? What implements can be used with this situation? or is it just good for tractor pulls and I need to sell it?
CNKS
11-15-2005 17:17:14
 Re: question about hitch for implements in reply to Raymond Vandervoort, 11-15-2005 10:20:43
If your tractor has indentations in the rear axle castings, it is likely that a Saginaw will fit, but you will also need the brackets that clamp to the axles. Saginaw fits anything from a C to a 560, but I am not sure the 340 has the indentations, as fast hitch attached mainly to the differential housing. Measure the space between the indentations and call Saginaw and ask. The "no room for a cylinder" is immaterial since the cylinder(s) are mounted on the 3-point itself.
Hugh MacKay
11-15-2005 13:58:26
Raymond: It would help a great deal if we knew the model number or letter of this tractor. There are aftermarket hitches as Dave has suggested. These hitches do have limitations. What implements would you like to use with this tractor?
Red Dave
11-15-2005 12:28:25
Try Saginaw for a 3 point conversion. Don't know if they have them for your tractor, but they might.
HAS
11-15-2005 10:33:39
What model of Farmall would that be that has that much HP without hydraulics? A Farmall A is only 16 HP.
There are a lot of "pull behind" implements - trailer plows, pull behind brush hogs, discs, etc. You can also use old horse-drawn implements. There is also a variety of tractor-mounted implements made specifically for that tractor that uses manual lifting systems.
Nat
11-15-2005 11:08:18
 Re: question about hitch for implements in reply to HAS, 11-15-2005 10:33:39
I don't think he said anything about "no hydraulics," only that the tractor just has a drawbar.
1959, Farmall, 35HP, rowcrop.... That could only be a Farmall 340. Unless of course he's got the year wrong, which is entirely plausible.
There are definitely plenty of trailing implements out there. You can do practically anything with a tow-behind rig, and in fact the vast majority of modern implements are simply pinned to the drawbar.
