Red/White Rear Light
Cityboy-McCoy
11-17-2005 10:51:21
I went to the tractor junkyard and found one of those rear lights with the red lens inside and the switch on top to change colors. Does anyone have an original switch, or know of a good substitute switch? The switch on this one has the knob missing, and in addition, seems to have some internal contact missing from it.
Thanks.
mike
RustyFarmall
11-17-2005 13:13:06
 Re: Red/White Rear Light in reply to Cityboy-McCoy, 11-17-2005 10:51:21
The new switch is available from O E M tractor parts. $24 for the switch, $6 for the plastic knob.
Janicholson
11-17-2005 11:35:33
The originals were very poorly waterproofed and rusted to dust.
I like a single pole double throw switch rated at 20 amps @120 volts. The best is a waterproof toggle (available on line, or at a very good supply store)
The center terminal is connected to the supply wire, and the other two are connected to the center terminal of two bulbs.
JimN
Cityboy-McCoy
11-17-2005 13:12:35
 Thanks for the help. in reply to Janicholson, 11-17-2005 11:35:33
