Order Farmall Cub Parts Online
cub governor timing mark ?
Rich Lorenz
11-18-2005 16:11:10
what does the timing mark on the governor line up with? Thanks
Daniel H.
11-18-2005 18:10:17
 Re: cub governor timing mark ? in reply to Rich Lorenz, 11-18-2005 16:11:10
Are you talking about the DOT on the gear? If so there are two DOTS on the camshaft gear that it goes between. The dots are on the front of the camshaft gear. I marked the gear teeth on either side with a grease pencil so I could see them when lining it up from the back (governor) side.
