Super C rear axle
Wreck7
11-19-2005 08:30:42
Can anybody tell me if a Super C rear axle is interchangable with any thing else? Like a C super H, anything? Anybody. HELP!
ACHodges
11-19-2005 21:50:47
 Re: Super C rear axle in reply to Wreck7, 11-19-2005 08:30:42
The 100 inch axels are rare. Will interchange with C,SC,200,230 for sure don't know about the 240. I would love to swap for some long ones but the freight to Texas may be more than they are worth. Would be a shame to cut them. I'll check and see how long the standard ones are.
Randy-IA
11-20-2005 19:10:07
 Re: Super C rear axle in reply to ACHodges, 11-19-2005 21:50:47
Hi , Check the hauling schedule to the left , you never know you might get them a ride to you for free . ...Randy
CNKS
11-19-2005 09:21:56
The C thru 230 were very similar, so the axles should interchange (I can be corrected) the H is larger diameter. I'm not sure about the 230's replacement, the 240. Keep in mind that there were two or three different lengths of that axle.
Keith-OR
11-19-2005 13:57:57
 Re: Super C rear axle in reply to CNKS, 11-19-2005 09:21:56
CNKS, is there anything special or rare about the 100 inch axles. If not I think I will cut the them off on the boy's Super C. Cause if he gets where he can ever drive it, he will be hanging axles on fence, post and anything else that get to close to the rearend...:>) :>) do you know the length of the shorter axles....thanks
Keith & Shawn
CNKS
11-20-2005 17:38:11
 Re: Super C rear axle in reply to Keith-OR, 11-19-2005 13:57:57
The numbers are tread with, center to center with the tires mounted. I don't know the actual length of the axles: 80, 88, 100. I would much rather see you replace them. You can shorten them, but they can't be lengthened.
