International 574 brakes
Fredthefrog
11-23-2005 06:53:23
The brake equalizer valve and brake master cylinders on my tractor leak profusely. I have them removed and have ordered the rebuild kits from my dealer. The orifice and screen in the small hose between the oil cooler return line and brake keep fill line is missing. This part is discontinued at the dealer. If I do not replace the orifice, am I just going to blow the seals on the equalizer valve and master cylinders again? Where can I find the orifice and screen in the aftermarket?
RAS
11-23-2005 10:37:00
 Re: International 574 brakes in reply to Fredthefrog, 11-23-2005 06:53:23
You don't need it. There is no pressure going to the master cylinders it is only return oil from the oil cooler. If was just a screen to keep trash out of the master cylinders.
