Engine block question
DWV
11-28-2005 18:40:35
On a farmall 400 tractor that has a replacement
block. The block casting date is 1967 the cast # on block is 365586-R1 and C-248 cast in place C-264 is normaly found.Have saw a few of these blocks before but never apart.My question,can someone tell me if the bore without sleeves is the same as a M or SM to 450? Forgot to mention
that I find the same # block listed as a replacement for SM and 400 in some parts books.
DWV
11-29-2005 06:45:46
 Re: Engine block question in reply to DWV, 11-28-2005 18:40:35
Thanks fellows for the replies,Runs good so hate to tear down to look but I have always been curious about the replacements that have C-248 0n block that is not ground off or restamped.May drop oil pan and check sometime if I don't get a answer.
colekicker
11-28-2005 20:49:11
I have a similar block that's a U-6 Powerplant. The # on the block had been ground off and had been re-stamped. The cylinder head on that engine had also been ground off smooth and another number stamped in. Very confusing situation. Maybe one of the more educated people with IHC from back in the day can shed some lite on this subject.
randy hall
11-29-2005 03:21:29
 Re: Engine block question in reply to colekicker, 11-28-2005 20:49:11
your block and head were rebuilt by ih. i have several m's like that with the original casting numbers ground off and new numbers stamped on. sorry that i can't answer dave's question.
