lookin at buying a 886 black stripe ? torque ampl
tugboattim
12-04-2005 07:04:49
hi all i,m lookin at a 886 backstripe with cab and air. this will be the most money i,ve ever spent on a tractor ten grand. shes got 5k hours on my bigest fear is the ta is there any tell tales to look for thanks in advance tug boat tim
Hugh MacKay
12-04-2005 08:33:24
 Re: lookin at buying a 886 black stripe ? torque in reply to tugboattim, 12-04-2005 07:04:49
Tim: Vet's advice is good. I think you will find all 86 series had black stripe. It was 66 series prior to 76 that didn't have the black stripe.
the tractor vet
12-04-2005 07:24:24
well the way to tell if the T/A is half desent is to get it out where ya can get her in high range and in either 3rd or 4th full throttel and start riding the brakes to bring her down to around 1500rpm and pull the stick back but be ready on the clutch if it stops dead in her track because it just may make a big lurch . And check and see how much ware is in the steering cylinder and tierod ends look for milky oil in engine and trans and rear end , look for oil in the radatior . Check shift linkage and any oil and hdy leaks ware on the three point . the rest is up to you.
