IH Coils
Mark Peters
12-05-2005 09:43:16
I have a couple original IH coils laying around here(ones with the seam around the middle). Is there a number on them or some way of telling if it`s a 6 or 12 volt ?
Tim Shaw
12-05-2005 18:10:50
 Re: IH Coils in reply to Mark Peters, 12-05-2005 09:43:16
My Farmall 350 which is a factory 12 volt has the small coil with the rib. The mounting bracket has the little tab that the resistor is attached to.
RustyFarmall
12-05-2005 10:17:37
If they are original IH coils, they are six volt. Only recently have original appearing 12 volt coils become available as an aftermarket item.
Mark Peters
12-05-2005 11:57:35
 Re: IH Coils in reply to RustyFarmall, 12-05-2005 10:17:37
Rustyfarmall, If I understand what you`re saying then, they never made a 12 volt coil with that rib around it in the 50`s or early 60`s? Thanks,Mark
DWV
12-05-2005 15:19:47
 Re: IH Coils in reply to Mark Peters, 12-05-2005 11:57:35
Mark the coils were on diesels,LP some 450-350 and others, and on tractors into sixtys were 12 volt.I have never found any I could tell apart by outside.Some of the bands on the 12 had a place to mount a resistor and some came with the resistor rivited to band.
John T
12-05-2005 10:00:44
Mark, if all else fails you could use an ohmmeter to measure their primary resistance as measured between their lil + and - terminals. If its in the 1.25 to 1.75 or so ohms range its my best guess it likely a 6 volt coil, but if over 2 to 3 and some over its my guess its a 12 volt coil. This is just a best guess as I have absolutely no specs or data on those coils, maybe Bob or Jim or Hal does and they can tell you the precise values??? They made some coils labeled "12 volts for use with an external ballast resistor" which are in reality more like 6 volt coils and some labeled "for 12 volt use only" what I would consider a true 12 volt rated coil.
Both coils and points are more "current" then voltage devices, its the current passing through or switched by them that sets up the induced voltages and energy transfer etc. If you use a 6 volt unballasted coil at 12 volts it could run hot plus the points wont last near as long due to the excess currents.
John T
Mark Peters
12-05-2005 12:02:40
 Re: IH Coils in reply to John T, 12-05-2005 10:00:44
John, I suppose what I could do is take a reading off of one of my other tractors` coils and compare the readings with these coils. I`m hoping to find that they`re 6V.Thanks,Mark
Janicholson
12-05-2005 12:07:08
 Re: IH Coils in reply to Mark Peters, 12-05-2005 12:02:40
If they are old, they are six V
John T has the numbers correct on OHMs
JimN
Mark Peters
12-05-2005 12:17:37
 Re: IH Coils in reply to Janicholson, 12-05-2005 12:07:08
Thanks for the help.Mark
