m crankshaft pulley
jdacih
12-06-2005 10:31:27
What is the best way to remove a crankshaft belt pulley on an m? thanks
El Toro
12-06-2005 16:46:16
 Re: m crankshaft pulley in reply to jdacih, 12-06-2005 10:31:27
You may want to make or have a puller made like this one that was designed for a Cub. Hal
PS: You should use a split bearing separator behind the pulley so it doesn't break your pulley.
Cost is in the $35.00 to $50.00 range. Use 3/4 18" allthread. They can punch those 13/16" holes.
http://www.ytmag.com/messages/459316.html
the tractor vet
12-06-2005 10:45:45
A big bearing spliter and big puller .
