Head Studs
Don Brien
12-06-2005 12:27:05
I need some more advice, The block out of the 400 i am rebuilding had a hole in the cylinder wall. I found a new block but i have no head studs in it. My question is can i use the studs out of the old block or should i just buy new ones. Also i was wondering how the best way to remove cam bearins without the special tool to do it. Thanks again
Joe Evans
12-06-2005 21:20:11
 Re: Head Studs in reply to Don Brien, 12-06-2005 12:27:05
Don't know what luck you'll have reusing the studs available to you but...
My brother's 400 engine rebuild turned more disastrous when trying to reuse old studs. He got new ones at the Case-IH dealer. They were pricey ($8.00 ea +) but wishes he had done that in the first place. FYI.
El Toro
12-06-2005 14:17:44
Your local Case/IH dealer may have studs. If you have a business in your area that sells all kind of bolts he probably has studs too or can get them. NAPA auto stores may have them too. Hal
PS: I see you have the size and length.
Dick Hamilton
12-06-2005 13:47:32
Head bolts up to 5/8-11 51/2 inches long are available from Hit and Miss Enterprises, P.O. box 157, Orwell, OH 44076. He has them down to 1/4-20 3" long. They are primarily into gas engines, but I'm sure they would appreaciate your business. Their web page is www.hitnmiss.com Dick in the cold Finger Lake Region of NYS.
Janicholson
12-06-2005 13:10:02
Double, or triple nut the top threads and turn the bottom nut to loosen. Work stubborn studs back and forth (tighter looser) in small amounts.
Heat on the block can help a bunch sense you are junking it. Sevier blows with a cold chisel on the block deck radiating away from the stud also swells metal.
Good luck. JimN
ChadS
12-06-2005 12:38:02
if you have a stud puller, then it may be easy to remove the studs and reuse them, I dont like using a pipe wrench on the studs, it can bend them, and scar them up pretty bad. I dont know where to buy reproduction head studs that would not cost a fortune,,, Im looking for a new or perfect pair for a H farmall too! Removing the cam bearings are easy, you can drive them out with a large socket, or a chistle, (spelling) Its putting em back in that it a pain without messin em up, I guess with alot of patience a block of wood you could install em,, if you can use some sort of hone to clean the cam bearing bosses out before you install them, it helps put them in easier,,, Watch where the holes are on the old bearings, to know where to put them back in the right place. ChadS
