W9 Distallate head
Roger in Iowa
12-12-2005 13:46:07
Is the head for a distallate W9 different (lower compression) than a head for a gas W9?
Thanks,
Roger in Iowa
gene bender
12-12-2005 16:56:03
 Re: W9 Distallate head in reply to Roger in Iowa, 12-12-2005 13:46:07
If you check the parts book you will find that the pistons were different. You should find several listed for hi-altitude and so forth.
Joe Evans
12-12-2005 14:32:53
I don't know for sure. (Seems I know nothing for sure nowadays!) However, it would stand to reason that a distillate head would have a lower compression ratio than a gasoline head.
Distillate has very poor anti-knock qualities therefore, it can't stand as a high of a compression ratio than gasoline. Heck, when the W-9 came out in 1940, gasoline itself wasn't all that great then, so the 335 gas engine had a CR of 5.4:1. Conversely, LP has good anti-knock qualities, and LP engines have typically higher CRs than their gas and distillate counterparts.
Many Nebraska tests show the LP versions of an engine besting a gasoline version in BHP.
