Super A Year Model
Klinton Guess
12-12-2005 16:50:18
How do I tell what year model my Super A is?
stan2270
12-12-2005 16:57:11
 Re: Super A Year Model in reply to Klinton Guess, 12-12-2005 16:50:18
Klinton, here you go - this info is posted under research and & info section: Year Starting Serial Number 1947 250001 1948 250082 1949 268196 1950 281269 1951 300126 1952 324470 1953 336880 1954 353348 The Serial Number is located on the left side of the clutch or transmission housing
CNKS
12-12-2005 18:01:14
 Re: Super A Year Model in reply to stan2270, 12-12-2005 16:57:11
The serial number is on the inside of the left seat support. 100-up is on the left side of clutch housing.
loko17
12-12-2005 16:55:42
The serial number will give you the info you are seeking. If you send me the serial number, I can give you the year.
Klinton Guess
12-12-2005 17:21:43
 Re: Super A Year Model in reply to loko17, 12-12-2005 16:55:42
The silver plate located under the seat on the side of the housing is very hard to read. The number I get from there does not match any numbers on the table. Is there any other place that I can find the serial number?
Nat
12-13-2005 05:05:31
 Re: Super A Year Model in reply to Klinton Guess, 12-12-2005 17:21:43
The numbers probably won't match exactly; the odds of that are about 1 in 20,000.
Every tractor has a different serial number. That's why they're called serial numbers. The list that was posted shows the FIRST serial number for each year. If your serial number is higher than the listed number for one year, but lower than the number for the next year, then your tractor was made in that year.
stan2270
12-12-2005 17:37:15
Klinton, what is the number that you see after the letters FAA on the serial tag?
Klinton Guess
12-12-2005 17:46:29
 Re: Super A Year Model in reply to stan2270, 12-12-2005 17:37:15
I'll have to go and check tommorrow, the tractor is at my dad's house. He is having trouble seeing the serial number. I will reply tommorrow if I can't figure it out. Thanks for your help.
Peabody
12-12-2005 18:04:28
 Re: Super A Year Model in reply to Klinton Guess, 12-12-2005 17:46:29
Klinton, while you're looking, and if the serial number plate is not readable, look for a flat milled "boss" on the block in front and above the distributor(or mag) I think above the #1 spark plug on the right side of the block (sitting in the seat), it has the engine serial number stamped into it. If the engine is original, it is typically identical or near the same as the tractor serial number.
