Iowa Gary 'er Someone Help!
Allan in NE
12-15-2005 05:53:10
Mornin' Guys,
Hydro 70.
This brass fitting is a "T", just ahead of the battery tray and coming straight up out of the tranny and it appears to tie to either end of the regulator valve and also in turn to the Foot-N-Inch pedal.
This thing was leaking like mad whenever I would move the tractor.
I think I have the leak stopped, but what does this oil do?
Thanks,
Allan
third party image
RAS
12-15-2005 12:47:29
 Re: Iowa Gary 'er Someone Help! in reply to Allan in NE, 12-15-2005 05:53:10
Allan the lines you are talking about are return or leak-off lines for the foot&inch valve and drive control valve and they dump back into the transmission. The fitting is just screwed into the cover and is not connected to anything under the cover.
Allan in NE
12-15-2005 13:15:58
 Re: Iowa Gary 'er Someone Help! in reply to RAS, 12-15-2005 12:47:29
Thanks Pard,
That's what I figured, but didn't know for sure 'cause I can't find an oil schematic for the thing.
Took 'er out again to my favorite "hill test track". Darned tractor will bury herself to the axles in reverse and absolutely kill the engine if I pull it hard enough; but in forward, she just by-passes when the going gets tough.
I'm gonna pull that left cover plate off next and see if I can find that forward pressure leak; gotta be in there somewhere. :>)
Thanks Buddy,
Allan
