Oil Addatives
Andrew Z
12-21-2005 11:02:46
Does anyone add oil additives to there tractors during the cold months? I was thinking of using some of that Marvel Mystery oil. Is there any advantage in using this? Thanks
Andrew
Don L C
12-23-2005 19:32:15
 Re: Oil Addatives in reply to Andrew Z, 12-21-2005 11:02:46
I was told many years ago "Marvel Mystery oil" was mostly kerisene(mis-spelled)...not to use it.....I was putting it in every change.....my oil usage went away.....
Dave in Connecticut
12-21-2005 17:12:48
Added wear caused by cold-weather starts, of course, can be reduced by some sort of heater. I just started using one last year on my H and probably won't go back to use without a heater.
alfred
12-21-2005 15:52:15
sraight 30w with a quart of Lucas oil stabilizer --year-around here. S0. DAK..
riverbend
12-21-2005 15:37:18
In addition to light weight oil, you might want to make sure that the tractor gets good and warmed up when you use it. I run a woven grain bag over 3/4 of the radiator to help it come up to temperature. Condensation can be a problem in cold weather.
kirk/ihcollector
12-21-2005 12:47:29
I only use "Lucas" additives!
Fluggie in Ia
12-21-2005 11:33:20
The only time I have added anything like Marvel Mystery oil was just before I was going to change oil & filter and I went out and worked the tractor good and got her warmed up for a few hours then dump the oil. The M.M. oil cleaned out any sludge build up but I do not recommend using it at all times. I agree with Rusty that proper vis. oil is all that is needed.
RustyFarmall
12-21-2005 11:10:42
I do not use additives. A good quality motor oil of the proper viscosity does not need anything added to it.
Andrew Z
12-21-2005 13:17:22
 Re: Oil Addatives in reply to RustyFarmall, 12-21-2005 11:10:42
Thanks guys for the replys andrew
