sleevespistons
Al Rose
12-22-2005 15:27:21
Anybody out there have any new or good sleeves for a WD-40 diesel? Sleeves out of a TD-14 or TD-18 would work too. Thanks Al
El Toro
12-23-2005 16:58:45
 Re: sleevespistons in reply to Al Rose, 12-22-2005 15:27:21
LAsleeves can make new sleeves for your tractor.
They would need one of your old sleeve's for a pattern. The cost would be $210.00. Their number is 1-800-822-6005 and email is info@lasleeve.com. Is the 461 cid correct on that tractor? Hal
hector gemme
12-23-2005 03:30:46
HI I have some use piston ,sleeve,new valve, ead gasket and more.HECTOR
Janicholson
12-22-2005 18:32:38
The following site is from a very reputable company LA Sleeve. They can make them, or have them in stock. Use the contact us button at the bottom of the page to inquire. There products are the finest alloy castings for extreme wear.
JimN
http://www.lasleeve.com/master.html
El Toro
12-22-2005 18:13:55
That engine should be the C-461. Try www.thefordsonhouse.com. Their number is 906-786-5120 or you can email them at info@thefordsonhouse.com. You can call the Mellen Cylinder & Sleeve at 1-800-621-0169 ext.27.
They should be able to tell you if they make a sleeve kit for the 461 engine. The bore is 4.75"
and the stroke is 6.5". Good Luck, Hal
