Farmall A/Super A Sickle Mower
JohnG(TX)
12-27-2005 14:11:35
I have a sickle bar mower for a Farmall Super A and I need it to work on a 1940 A. It bolts up just fine. The main difference is that this mower is set up for hydraulic lift, and my A has no hydraulics. Does anyone know of a way to lift this thing manually, or have the proper lift parts for the standard A? It is an A-24 mower, 7 feet.
Also, I need the tractor side of the PTO shaft.
El Toro
12-27-2005 18:19:41
 Re: Farmall A/Super A Sickle Mower in reply to JohnG(TX), 12-27-2005 14:11:35
The A had a spring loaded lever for lifting the implements. It was long lever to give you leverage. If your tractor is missing this lever
you may be able to find one in a salvageyard. Here's a web site for salvageyards. Hal
PS: There was a lever for tilting the plow point when the plow was installed too.
http://www.epartdirect.com/index.php?t=fc&s=s
